Pyro fire color noise not move with the fire _Default rest field
jingyisw
  • 2 weeks later...
  • 3 weeks later...
do you have a file you can share?
actually,i use the basic stuff ,just  the shelf tool,which called pyro flame,then i turn on the restfield toggle ,which in the pyrosolver node under the advanced tab.then i turn on the noise option from the pyro shader node under the firecolor tab.then render it out ,not work. noise looks flat ,no 3D feel
