Tyfx567 Posted September 12, 2014 Share Posted September 12, 2014 (edited) I have replaced the file with just a cube so you guys can still see what is going on. It's very basic. It's just a box with points at the center of each piece telling what is active and what is not active. however when I put this expression: point("/obj/Angel/AC", groupbyvals("/obj/Angel/AC", D_POINT, "name", $OBJNAME), "ACTIVE", 0) in the active value DOP that I got from another dude on a forum on here, that expression doesn't work. Can someone please tell me what I am doing wrong here? This is for a demo reel project so I am on a time crunch..that's why I'm posting this. Thanks so much!! Angel_Destruction_3.hipFetching info... Edited September 13, 2014 by Tyfx567 Quote Link to comment Share on other sites More sharing options...
xray Posted February 12, 2015 Share Posted February 12, 2015 groupbyvals() returns a string. The point expression expects an integer (though a float will work). You need to convert the string returned by groupbyvals() to a number. hscirpt has the atof() expression which converts a string to float. try: point("/obj/Angel/AC", atof(groupbyvals("/obj/Angel/AC", D_POINT, "name", $OBJNAME)), "ACTIVE", 0) Quote Link to comment Share on other sites More sharing options...
Tyfx567 Posted February 13, 2015 Author Share Posted February 13, 2015 Thank you very much. I found a solution to this a while back. It wasn't what you suggested but it never hurts to have multiple ways to do something and to learn something new. Thank you so much for your useful input! Quote Link to comment Share on other sites More sharing options...
WEN Posted January 14, 2017 Share Posted January 14, 2017 I encounter the same issue,Can you tell me how to solve it? Quote Link to comment Share on other sites More sharing options...
Tyfx567 Posted January 14, 2017 Author Share Posted January 14, 2017 (edited) Hey Wen, actually, this post is extremely old and I figured out how to do it much more efficiently since then. I made a sample file for you to learn from. I've learned a whole lot since then and it makes me feel stupid that I did it the hard way. Notice that I have "overwrite attributes from sop" checked on in dops in the packed object. Watch the "bullet masterclass" show to learn more techniques. Also watch "wrangle workshop" on vimeo if you don't know vex. If you need help don't hesitate to ask. I enjoy helping others when I know things Active_showing.hipFetching info... Edited January 14, 2017 by Tyfx567 Quote Link to comment Share on other sites More sharing options...
