finding chs
Follyx
To see all available parameters for a node you can click on the little gearbox icon in the parameter interface and click "Edit parameter interface".
This should give a better organized view of all the parameters/channels that the node has.
`chs("../../ptgroup")`
means it is on the node 2 levels above the node that contain parameter with this expression
so imagine the node with this expression is node1
and if node1 has path, /obj/geo1/subnet1/subnet2/node1
then relative path  ./ would refer to node itself, so node1
../ would refer to node one level higher, so subnet2
../../ refers to node 2 levels higher, so subnet1
therefore chs("../../ptgroup") refers to parameter called ptgroup on the subnet1 node
the full path to that parameter would be /obj/geo1/subnet1/ptgroup
the easier way to get to that parm would be RMB on your parameter with expression and from menu choose More/View Dependencies
then change View mode to References and find your referenced parm, if you select it, you will see in bottom of that window Expression and a little arrow, which will take you to that node directly
