acey195 Posted October 1, 2014 Share Posted October 1, 2014 Hello all, Im trying to composit a set of images using some vops in the comps/img context. This works fine, however if I update the source images and recomposit, it still uses the old textures from memory. Since it uses a vopcop2gen to load the source images, I cannot use the "Reload Sequence" button as with the file input in cops. so I basically have to force clearing the cache. This is possible using the python shell with the "%texcache -c" command. My problem is that this function doesn't seem to be available outside the python shell, as it doesn't seem to work for callback scripts for instance. Does anybody know the proper syntax for using this function in a callback script, or a different workaround? Twan Quote Link to comment Share on other sites More sharing options...
kgoossens Posted October 1, 2014 Share Posted October 1, 2014 Hi Twan, Long time no see. use hscript instead hou.hscript("texcache -c") hou.hscript("glcache -c") Quote Link to comment Share on other sites More sharing options...
acey195 Posted October 1, 2014 Author Share Posted October 1, 2014 Hi Kim, thanks a bunch! Yeah indeed, In the end I didn't went to SideEffects, but I guess everything worked out here. Hope you're doing fine as well. Quote Link to comment Share on other sites More sharing options...
acey195 Posted October 2, 2014 Author Share Posted October 2, 2014 I've now tested this and it seems to work partially, however it still seems to linger in the "COP Cook Cache" but there doesn't seem to be a corresponding HScript command to clear this specific cache unfortunately. However again, if I just force the cop node(s) to recook it works as well something like: hou.node("./CombineOutput/vopcop2gen1").cook(True) So you basically have to clear the Cache AND recook the nodes, either doesn't cut it, it needs to be both. But thanks again! Quote Link to comment Share on other sites More sharing options...
3iart Posted October 2, 2014 Share Posted October 2, 2014 try hscript : compfree opcook -F python hou.cache.composite hou.Node.cook() cheers </R> Quote Link to comment Share on other sites More sharing options...
