hatrick Posted October 28, 2014 Share Posted October 28, 2014 (edited) Hi, How can i delete fractured pieces (packed prims) within a cetrain area/below a certain point, inside dops. Thank you Lucas. Edited October 28, 2014 by hatrick Quote Link to comment Share on other sites More sharing options...
Rainroom Posted November 10, 2014 Share Posted November 10, 2014 If you are using packed primitives, you can use a sopsolver inside the dopnet to do virtually any sop-level point manipulation/deletion work. You need to use a multisolver and connect bullet solver and sopsolver in the second input respectively. The same logic that you apply in sop-level to delete points will work inside the sopsolver as well. Quote Link to comment Share on other sites More sharing options...
