FEM stiffness and damping controlled per point attribute
kgoossens
Hi, is it possible to set up a system where the stiffness and damping is controlled using (point/volume) attributes?
The idea is to have interior structures having varying properties.
I've tried some approaches by adding field data to the finiteelementsolver and by trying to change the solidconfigureobject DA. There I see that both stiffness and damping are used by specific solidshare, solidstretch and solidvolume nodes. So is there a way to change this that the values can be different over the geometry?
Or should I take a different route here by making the tetrahedralize densities different within the object?
Cheers,
