Hailstorm effect slow after a few pieces... why?
Magasul
Hey everyone!
I am trying to create a hailstorm effect with raining huge blocks of ice (hail).
I set up a simple simulation where there is a grid and each frame a random point is selected and a hail is copied onto it, then with a sop solver it gets merged in. It all works, but after a few pieces, the simulation slows down drastically.
They are packed and the DOP uses autofreeze, but still it's slow...
Please somebody with experience look at it and tell me why? Thanks! :)
Jegeso_001.hip
Anytime someone asks a 'why' question, Feynman's answer comes to mind ;)
No time to do some tests; did you run the Performance monitor and see the slowest bit; how about simulating a lightweight particle system and attaching a the geo to it, or, running the sim and baking it out perhaps
I did tests. I replaced the ice geometry with a simple cube, but it is still slow. I just don't get it, when I see simulations running smoothly with hundreds of simple object, why does only a few slow this down?
I ran performance monitor and the rigidbodysolver is red, but even when tweaking it to less substeps it is still slow....
I need these hails (ice) to drop to the ground and bounce realistically, but I need maybe hundreds of them. I am using bullet but it's slow as hell....
I have an i7-2700K CPU with 3,8GHz
16 GB DDR3 RAM
and an NVIDIA GeForce GTX 560 video card.
I don't think that's a bad PC but even after connecting a Box SOP to xform 3 it still slows down.
Here is a screenshot of my performance monitor at frame 300:
Edited by Magasul
First hundred frames takes about 20 seconds.... (after clearing cache and reseting simulation)
Do you have a hip file lying around where you emit rigid bodies like this and you know it works so I can test it? Thanks!
(Or could you tell me the best solution for making a hailstorm with irregularly shaped ice spheres that bounce around and hit eachother after they land, then after a small roll stop as if they landed on grass?)
Edited by Magasul
You would normally have hero pieces up close to camera - with the most detail and better simulations, then lesser versions background.  It could be a great big mixture of RBD, bullet, particles
When you're doing sims and it's running 120fps I'm laughing - get into detailed water sims, or fluids where it'll take many many minutes, to do one frame.
Modo is probably fine for that sort of simulation, what Houdini can do is give you a great workflow to optimise, or mix in other simulations too. You should still be able to get great speed out of Houdini but the main part is it offers a lot more than sim speed ;)
