Copy Sop, Keep Detail Attribute
schiho
Detail Attributes from the second input, AttribPromote sounds like an workaround, i want to use the benefits of global variables, which are light-weight. promoting it to primitives would generate redundant information. The Detail Attribute in my case is just a string, which holds the originalfilename, so that i can later export with this same filename.
