centroid in pointWrangle
haggi
I try to get the centoid of an object in a pointWrangle node. First I added a float3 attribute to the pointWrange and set the values of this attribute to the centroid of my object like: centroid("../myCube", D_X) etc. This works fine, the values are updated. Now I try to use this attribute in my pointWangle code  with: `chs("centerAttribx")`. But it seems that this procedure does not update the values in the pointWrange node.
My solution is to create a point with an add node set the position of the point to the centroid and plug this node into the second input of my pointWrange node. This works so far, but I'd like to know if there is a more elegant way to get the centroid directly from within a pointWrangleNode.
Hi Haggi,
I was wondering if you could share that file with us. I was under the impression that you can't run Houdini expression language in wrangle nodes, and that you were limited only to VEX. I would love to learn how you got that to work. I have tried using expressions like centroid() in the past, but remember getting errors due to that.
Thanks,
Ilan
  • 2 years later...
  • 3 years later...
