get object from frame?
Juzwa
I made some procedural rocks. I assigned a simple expression $F on few attributes to get variations very fast and so I could wrtite out the rocks. So now I have a lot of rocks in one single file sequence.
So now I want to use those rocks to model my surface. How can I use this sequence to get random rocks? Eg load a single random frame from that sequence
using a copy sop, enable stamp inputs and create a variable eg: rocks with a value of $PT.   On your file node you are reading in using the following expression:   $HIP/rocks_library/rocks.`floor(fit01(rand(stamp("../copy1","rocks",0)),1, 240))`.bgeo  (assuming you have 240 different rocks, change this as needed.)
Use a Copy SOP node, File SOP node, and Time Shift SOP node. Set the shift on the time to the value of the rock to load. I've attached an example scene file. Instancing could be another option depending on the nature of your workflow. If you don't plan to instance than writing the rocks to disk might not be worthwhile.
rockLoader.hip
Unfortunately I still dont understand something. When I use your Illusionist scene everything works fine. But when I make exactly the same setup I get copied only one rock?
I tried without timeshift node with this expression `floor(fit01(rand(stamp("../copy1","rocks",0)),1, 240))` but it evaluates to some 3 digit random number (eg 154). And I use 4 digits in files (eg 0154). And i get an error "Unable to read file.....154.bgeo"
[...] this expression `floor(fit01(rand(stamp("../copy1","rocks",0)),1, 240))` but it evaluates to some 3 digit random number (eg 154). And I use 4 digits in files (eg 0154).
change it to
`padzero(4,floor(fit01(rand(stamp("../copy1","rocks",0)),1, 240)))`
