Fluid Container Clipping
raptorus
Hey guys, Hello dear Odforce-Community
Im a young CG-Artist, using Houdini for a year or so now (not as my main 3d package)
I have a problem with the dynamic resizing of my fluid container. The container is "clipping" the fluid and dont resize correct.
I cant explain why it is so, because the "Fire"-Fluid-Container resize correct only the blue "Ice"-Fluid-Container resize incorrect.
But the settings in the two containers are nearly the same.
The "Bounds" settings in the resize_container couldnt help me.....:/
Here the video:
http://vimeo.com/112612980
around 0:04 sec you can see the clipping on the left side
The .hip file of the szene is attached.
clipping_container.fbx.hipncFetching info...
A lovely looking exercise!
Pradeep beat me to it, but Field Cutoff of 0.0005 seems to do the trick. Of course the simulation will become a bit slower as the container is less aggressively scaled down, so you might want to find a sweet spot for that..
