Controlling your fractures in houdini tutorial help - Digital Tutors T
Hi guys,
I am having 2 issues with this tutorial, and hoped that someone might be able to shed some light on my mistakes.
It is somewhat similar to this topic posted by Ispep...
http://forums.odforce.net/topic/21293-controlling-your-fractures-in-houdini-tutorial-help/
...I did find some useful information in the aforementioned post, but my issues are a little different.
1. On creating the active and passive points, the attribute transfer seems to create the point colour correctly and I'm not receiving any errors, when I run the simulation, the pieces that are active are random and do not seem to utilise the attribute transfer at all.
2. I also had an unresolvable problem creating the depth mask for fracture pieces. Although I (think) I followed the tut correctly, the pieces are not masked from inside to outer faces (black to red), they seem to be randomly applied.
Much apologies for extreme noobness :)
Any help would be really appreciated.
I'm currently running 13.0.593
Here is the file: https://www.sendspace.com/file/3srqz9
Thanks in advance
you are using $OBJ in the lookup expression, I dont know the order of of dop process operations but it may or may not be in ID order, $OBJID may or may not be in 0 based order. try opdigits($OBJNAME).  You need to make sure that point 0 aligns to piece_0, point 1 aligns to piece_1 and so on.
  • 2 years later...
