in shop noise problem
in your Mantra ROP reduce the Noise Level to 0.025 or less and increase your Pixel Samples. What you're seeing is the white micro-polygons being rendered/not-rendered. Since they're so small you'll need to increase the quality of your render. Also maybe increase the sampling of your light.
If you want cheaper small dots use point rendering maybe.
