Distribute fluid meshing
Partitions is one way to do it but then you multiply the load on the file server and network since each partition still loads the entire frame of particles from the simulation cache. A more efficient way would be to mesh one complete frame at a time on each machine so there's no duplicated data read for any of the workload. It might not be a big deal for a small simulation but for example if the simulation cache is 100GB and there are a dozen partitions now you're talking about transferring 1,200GB of data instead of 100GB.
Edited by lukeiamyourfather
You could also distribute the vdbfromparticles task over multiple computers by slicing up the points into clusters with a bit of overlap.
> create a grid of boxes
> keep only one box (current WEDGE)
> delete all FLIP particles outside the box
> vdbfromparticles > convert vdb to polygons
> clip geometry outside box.
> load all wedges and fuse geometry.
