rolfcoppter Posted January 27, 2015 Share Posted January 27, 2015 Hey guys, I have a question and im not sure if the answer applies to Vops or expressions or something else but... Say i have a simple box scattered and a sphere passing through it transfering an attribute with a value of 1 to the points it touches. is it possible to have an expression or something that goes like... when this attribute (on a perpoint bases = 1) then subtract 0.1 per frame from that attribute from then on ? I appreciate any help! thank you Quote Link to comment Share on other sites More sharing options...
Jason Posted January 27, 2015 Share Posted January 27, 2015 Yes, but because the current value relies on the previous frame, you must "simulate" it: In a Solver SOP, use a Group SOP to add the points to a point group with Expression doing your condition, and then in another SOP, subtract 0.1 from the attrib for any points in that Group. Quote Link to comment Share on other sites More sharing options...
rolfcoppter Posted January 27, 2015 Author Share Posted January 27, 2015 (edited) Thanks for the reply Jason. That is exactly what im looking for i just have a couple questions on that say the point gets added to the group on frame X how can i make it start subtracting on that frame X and each point having a different "frame x" where its going down. EDIT: I assume a forEach Sop would work but if i were to do -0.1*F if this happened on the 75 frame it would subtract 7.5 instantly. how can i do -0.1 every frame and not 0.1* Frame. Edited January 27, 2015 by rolfcoppter Quote Link to comment Share on other sites More sharing options...
