Dust questions
jordancario
Hey, Im a vfx student right now and I've been trying to learn houdini on my own for the past little while.  For a class project I need to be able to have dust kick up from the ground for a vehicle landing, a rotor wash type effect.  I was hoping smoeone here would be able to give me ideas on how I can at least get started.
As with most things in houdini there are many ways to accomplish something.   Here is one way to get it done.
Using an attribute transfer, transfer the color from your collision object with the ground plane, delete all the geometry that wasn't transfered and add normals to the direction your want the dust to move.  Use the normal direction to set your velocity and then turn it into volume source.
With the dopnet set the start frame to your impact frame, and on the source node set a frame value for it to stop emitting from.   Then it comes down to tweaking the look that you want.
To get really nice details then take your fluid sim and advect particles.  this will give you some really nice detail.  With the particles set the pscale to set the particle size, then add a color.  When rendering it, turn on motion blur to get a nice look (this has to be done on the mantra node, and on the geometry node.  on the geo node its called geometry blur under the Render tab.)
I have attached a sample file to show this.
dust_impact.hip
  • Like 2
Start with a particle sim that you like.  And then with your fluid source node change the method from build sdf to stamp points.   Then on the lower tabs there will be a stamp points tab,  adjust the sample Distance to get a nicer looking source.  The sample distance is the value around each particle that a volume will be created, the larger the number the bigger the source volume.  It may take some time  to adjust the look you want.
Hi Sierra62,
I saw your response here and I was wondering if you could help me with a simple simulation.
I'm trying to break a wall with a collision and then make it collapse with RBD, so far so good.
Then I'm emitting some debris from the shelf tool and I cant figure out the way to replace those points with actual geometry (sphere for exemple) and make them collide with my RBD sim.
Could you help me please?
I've attached my scene to this post.
Thank you!
Debris_collision_N_Geo.hipnc
  • 6 months later...
  • 3 months later...
