ayidi Posted January 28, 2015 Share Posted January 28, 2015 (edited) The load time in Mantra has a lower bound averaging 5.4s. Load Time: 1.37u 0.09s 5.40r Render Time: 9.29u 0.64s 8.37r 2.97 (35.4%) Render Time 5.40 (64.5%) Load Time (ignore the actual times, the importance is the bottleneck caused by load time) The problem is the load time is not shared between frames, therefore rendering an animation for testing requires a very long time. At this rate a 2 min scene takes about 7 hours to render. How can I lower the Mantra load time or share it among frames? Unfortunately, I'm using apprentice (no IFD) and changing spatial structure makes no difference. Rendering with OpenGL is not an option. Edited January 28, 2015 by ayidi Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted January 28, 2015 Share Posted January 28, 2015 If it's going to be pretty light scenes, maybe you could write a script to open several hbatch sessions and render in parallel? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 28, 2015 Share Posted January 28, 2015 Something sounds up with your computer: Simple box and point light to MPlay H14 on OsX. Default settings Load Time: 1.20u 0.09s 0.19r Render Time: 18.62u 2.11s 3.29r Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 28, 2015 Author Share Posted January 28, 2015 Something sounds up with your computer Yes my computer is definitely an issue, but lets pretend the load time is the bottleneck. The Render View panel does exactly what I want, it renders without re-loading the scene. It seems that creating a script that saves a frame from the panel at every frame is a better option than John's solution. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 28, 2015 Share Posted January 28, 2015 Try the attached - the Preview options have been enabled on the MantraRop and drop the Load time a touch here from 0.19 to 0.14. Hopefully it's has a greater impact. DefaultBox and pointlight.hip Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 28, 2015 Author Share Posted January 28, 2015 Try the attached - the Preview options have been enabled on the MantraRop and drop the Load time a touch here from 0.19 to 0.14. Hopefully it's has a greater impact. Enabling the preview option in the Mantra ROP does not reuse the loaded geometry. At every frame a new mantra instance is created. You can tell by looking at: reading geometry from stdin /obj/box/box1 (6 primitives) The Render View panel is using one mantra instance and doesn't reload the geometry. It would be nice to get this behavior. Quote Link to comment Share on other sites More sharing options...
pezetko Posted January 28, 2015 Share Posted January 28, 2015 I had exactly same problem in H13 (cannot test it H14 yet). Ifd didn't helped. It took more time to process (load) the scene then render. IPR render on the other side was blazing fast. There is little issue with IPR update between frame that doesn't work always correctly, sometimes there is too much change in geometry. But if the sequence is coherent it usually works without problem.Please submit your issue as RFE (you can add pointer to mine: RFE #64474) http://www.sidefx.com/index.php?option=com_content&task=view&id=768&Itemid=239Thanks The load time in Mantra has a lower bound averaging 5.4s. Load Time: 1.37u 0.09s 5.40r Render Time: 9.29u 0.64s 8.37r 2.97 (35.4%) Render Time 5.40 (64.5%) Load Time (ignore the actual times, the importance is the bottleneck caused by load time) The problem is the load time is not shared between frames, therefore rendering an animation for testing requires a very long time. At this rate a 2 min scene takes about 7 hours to render. How can I lower the Mantra load time or share it among frames? The load time is the bottleneck. The Render View panel does exactly what I want, it renders without re-loading the scene. It seems that creating a script that saves a frame from the panel at every frame is a better option than John's solution. 1 Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 28, 2015 Author Share Posted January 28, 2015 (edited) Please submit your issue as RFE (you can add pointer to mine: RFE #64474) Submitted the RFE, hopefully we don't have to wait until 15 to save a frame range using the IPR. Tried to hack my way around it and iterating through the pixels takes around 1.5 seconds (640 x 480). for y in range(height): for x in range(width): rgba = self.panel.pixel("C", x, y) ncalls tottime percall cumtime percall filename:lineno(function) 307200 0.140 0.000 1.399 0.000 hou.py:45397(pixel) Edited January 28, 2015 by ayidi Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 28, 2015 Share Posted January 28, 2015 Submitted the RFE, hopefully we don't have to wait until 15 to save a frame range using the IPR. Tried to hack my way around it and iterating through the pixels takes around 1.5 seconds (640 x 480). What specs are your machine? Sounds like an upgrade will guarantee reduced load times. A 2 min, 2880 frame, render should be ~7min for load time on a dual 6 core @ 3.33. (2880*0.14)=403/60=6.72 Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 29, 2015 Author Share Posted January 29, 2015 What specs are your machine? Sounds like an upgrade will guarantee reduced load times. A 2 min, 2880 frame, render should be ~7min for load time on a dual 6 core @ 3.33. (2880*0.14)=403/60=6.72 Don't get hang up in the actually seconds, what matters is that the load times can be considerably big and affect the render time considerably. The numbers were from a machine running Mavericks and now with Yosemite the load time decreased to ~0.13s. Even with a small scene the load time becomes considerably big. I created a small script that uses IPR to save an animation. Using a small 320x180 resolution, I'm getting twice the speed or more. A small resolution is crucial since getting the pixels from the IPR is not efficient, at 320x180 takes about ~0.65s to read the pixels and save an image. iprPane = hou.ui.findPaneTab('panetab4') # Render View ipr = renderIPR.IPR(iprPane, 0.5) renderIPR.profile(ipr.render) # vs mantra = hou.node('/out/mantra_ipr') renderIPR.profile(mantra.render) python2.7libs.zip Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 29, 2015 Share Posted January 29, 2015 thanks - what is the machine specs please. This will help with future testing. Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 29, 2015 Author Share Posted January 29, 2015 Platform: darwin-x86_64-clang5.1-MacOSX10.9 Operating System: Mac OS X Version 10.10.1 (Build 14B25) Number of Cores: 8 Processor: 2.2 GHz Intel Core i7 Physical Memory: 8.00 GB Number of Screens: 1 Screen 0: 1680 x 1050 at 0,0 OpenGL Vendor: ATI Technologies Inc. OpenGL Renderer: AMD Radeon HD 6750M OpenGL Engine OpenGL Version: 4.1 ATI-1.28.29 OpenGL Shading Language: 4.10 Detected: ATI Consumer (Mac version) Quote Link to comment Share on other sites More sharing options...
edward Posted January 29, 2015 Share Posted January 29, 2015 What's the nature of your scene? Is the load time slow because of shaders or geometry? Those timings look pretty atypical to me. Are they stable? eg. If you render out a sequence of 10 frames, are those times per frame the same every time? Recall that things can get faster once your OS has warm caches. Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 29, 2015 Author Share Posted January 29, 2015 10 Frames (320x180) Render View (IPR) 2.0s per frame (timer) + ~0.6s getting pixels and saving .... Load Time: 13.66u 1.05s 9.36r Render Time: 17.39u 1.15s 9.98r Load Time: 17.40u 1.16s 12.02r Render Time: 21.12u 1.24s 12.64r Load Time: 21.12u 1.25s 14.80r Render Time: 24.77u 1.31s 15.37r Load Time: 24.77u 1.31s 17.53r Render Time: 28.36u 1.38s 18.09r Load Time: 28.36u 1.38s 20.34r Render Time: 31.98u 1.48s 20.95r Load Time: 31.99u 1.48s 23.09r Render Time: 35.72u 1.54s 23.68r Load Time: 35.73u 1.54s 25.86r Render Time: 39.42u 1.61s 26.45r Total Time: 27.46s Mantra ~7.6s per frame Load Time: 3.64u 0.24s 2.51r Render Time: 13.11u 1.46s 7.21r Load Time: 3.63u 0.25s 2.95r Render Time: 12.84u 1.74s 7.66r Load Time: 3.45u 0.22s 2.98r Render Time: 12.98u 1.31s 7.72r Load Time: 3.49u 0.22s 2.98r Render Time: 12.83u 1.42s 7.86r Load Time: 3.99u 0.29s 2.94r Render Time: 13.11u 1.34s 7.65r Load Time: 4.06u 0.31s 3.06r Render Time: 13.50u 1.53s 7.96r Load Time: 3.49u 0.23s 2.97r Render Time: 12.93u 1.50s 7.69r Load Time: 3.68u 0.26s 3.02r Render Time: 13.16u 1.39s 7.73r Load Time: 3.68u 0.26s 2.96r Render Time: 12.98u 1.36s 7.51r Load Time: 4.20u 0.31s 2.95r Render Time: 13.54u 1.63s 7.67r Total Time: 91.18s 3.3x performance increase! iprSave.zip Quote Link to comment Share on other sites More sharing options...
edward Posted January 29, 2015 Share Posted January 29, 2015 Er, you're rendering a static frame sequence? Let me rephrase that. I'm not saying that you can't get a speed up at all. Certainly for specific situations you can. I was more interested in the type of scene that you're actually trying to render that exhibited those skewed timings. Or have you only been trying on test play scenes? Quote Link to comment Share on other sites More sharing options...
ayidi Posted January 29, 2015 Author Share Posted January 29, 2015 My goal was to speed up the render time in a static scene for testing purposes. Ex. debugging shaders, quick animation previews, lighting, etc. I really like the IPR viewer but it lacks a way to preview an animation. Something like a ram preview (AE) would be ideal. Sorry, at the moment I've only done test play scenes. Quote Link to comment Share on other sites More sharing options...
