Werner Posted January 28, 2015 Share Posted January 28, 2015 Here is something I started in Houdni 13 and picked up again when H14 came out.I'm learning/exploring, so it is taking a bit of time to find a good workflow for modeling. H14 made that easier, and hopefuly it will improve some more. 1 Quote Link to comment Share on other sites More sharing options...
DaJuice Posted January 29, 2015 Share Posted January 29, 2015 Looking great Werner, I like your render as well. Only thing that bugs me a bit is the smoothing angle on the chin. As far as modeling, there are a few things that I personally like to do: F6-F12 are set to various modeling operations and bound to extra buttons on my mouse (Logitech G700). Global/Local toggle for PolyExtrude is set to Z (because it takes too long to right-click and change it from the menu and I change that often). Detach Handle is set to C rather than ' so it's more accessible. I don't really use primitive snapping much so losing that shortcut is no biggie. Shift-W will toggle between smooth shaded and smooth+wire shaded. Likewise it toggles flat shaded to flat+wire shaded. You probably already know that, but just in case. Quote Link to comment Share on other sites More sharing options...
