OpenGL/GPU functions without GUI under Linux
danw
Hey all.
Just wondering if anyone's set something like this up... is it at all possible to set up a command-line only installation of Linux, that not only loads the proprietary nVIdia drivers, but can run GPU-accelerated tasks from the command line without there being an X server running?
Hi Dan,
I'm afraid I can't speak for the OpenGL side of things, but I do know you can set up a "headless" Linux box for OpenCL GPU computing.  Partly because I just (re-)tested it, but also because HPC computing is a big part of NVIDIA's GPU strategy, and they make things like the Tesla cards that are designed mainly for server-side computing.
Edited by johner
Thanks for the info everyone.  Yeah, I was wondering if it might be possible to farm out OpenGL ROP playblasts but not bother with a full GUI install (and dealing with X's annoying insistence on failing if there's no monitor attached).  Seems I'd be best off just getting some of those dummy-VGA plugs instead :-)
  • 4 weeks later...
On a related note, I haven't had luck running the OpenGL ROP, I get this error:
No protocol specified
Qt Warn: : cannot connect to X server :0
The computer has a graphics card, and I even plugged in a display, but I can't run OpenGL ROPs via commandline or hqueue.
Is there anything besides just having a graphics card plugged into the machine, that would be required? It's Linux Mint 17.1, Nvidia 340 drivers (can't remember specific revision), if that helps, gcc 4.8 build
Thanks!
*Edit* I'm pretty sure this is related to Hqueue; I can render an OGL rop via hbatch just fine
Edited by goldleaf
