Orienting normals
Spaz8
I seem to run into this issue a lot.
I create a line of points, and then use the sort $TX-$TX2 .. trick to get all the normals pointing down the line. The heading and pitch are fine, but the "bank" is very often not what I want. Which is obvious when I begin to copy geo to those points.
I have tried using things like polyframe, and even blending normals from two sources with a vop sop without much success.
Is there some sort of "up vector" trick I don't know of. I seem to alwayy be able to only get 2 of the 3 orientations of the normal how I want.
Thanks for any suggestions.
Thanks for the example file.
Had to open it in H14 apprentice. The pointvop_setup_vector node errors in 13.
I don't see anything super 14 specific, so should be easy to replicate, thank you.
Edited by Spaz8
