VEX - delete by attribute
Juzwa
I've created primitive attributes on most of the pieces of my model. So when it comes to fracturing I can split the geo very fast by attribute.
I think it needs to be done in delete SOP, primitives entity, expression or pattern, maybe a foreach. But I'm not sure what is the expression that I need to do that. I tried to set each attribute some value and then use this:
@myAttribute > 0
But It does not work and I know why. I think I need sth like:
if (currentAttribute == @myAttribute)
Edited by Juzwa
If you use a blast node:
@myAttribute > 0 without the spaces "@myAttribute>0" should work.
Or if your attribute has also been declared as a variable "$MYATTRIBUTE>0.5" should work in a delete node in the filter expression parameter.
In my experience, using the blast node has much faster results.
Reply to original topic (VEX - delete by attribute)
VEX solution:
drop down an attribwrangle then enter this code:
if(@myAttribute > 0)
removeprim(geoself(), @primnum, 1); // if you want to delete points owned by primitive itself
or
removeprim(geoself(), @primnum, 0);
