MotionBlur Problem, FlipFluid to Maya
luc255
I have a problem when I import my flipFluid on maya, it is impossible to use the motion blur with Arnold Render or RedShift.
I had the same problem when I use houdini Engine or Alembic.
However, it works with all traditionnal polygonal shape or particular system.
Do you have any idea, why it's not working ?
Enclosed you can find an example.
Thank-you.
example.zip
Edited by luc255
Thank-you for your answer,
Nice article michaelb, So I am forced to use SOuP plugin in my pipline..
because when I change "velocityPV" to "v" that don't works.
I guess with redshift it's done ?
Thanks !
Edited by luc255
After some tests, I have the same result with or without SOuP plugin.
Enclosed, you can find several exemples.
I have one issue, why do I have a little motionblur when the velocity is 0 ?
Thanks !
post-12244-0-07145700-1424267638_thumb.j
post-12244-0-27141800-1424267640_thumb.j
Edited by luc255
  • 1 year later...
