Setting "orient" attribute multiple times on scattered points
Hello all! First post here!
I'm working on an OTL that scatters points and then instantiates objects on it.
I have many layers of potential rotation patterns that can overlap or not (i.e: imagine 3 VOP SOPs on top of each other that can all output a quaternion to the "orient" attribute)
I'm just wondering if this workflow is acceptable or if I need to worry about data corruption as I am always reading and writing from and to the same attribute.
Any advice?
Thanks!
Any advice?
Thanks!
 you don't need to worry about data corruption.  Just set your orient however you want.
 -G
