skip_odforce Posted March 9, 2015 Share Posted March 9, 2015 (edited) Hi all, If I want to delete the data shown in my attached image. How do you do that? I know I can use a delete node and typed " @name=vel.* " in the group field, but I don`t know how to do that in the situation. Do anyone can help? Thanks a lot. Edited March 9, 2015 by skip_odforce Quote Link to comment Share on other sites More sharing options...
Skybar Posted March 9, 2015 Share Posted March 9, 2015 You can delete by the primitive number. So in a Blast SOP or Delete SOP, write '4' in the Group-field and you will delete that Surface volume example. Quote Link to comment Share on other sites More sharing options...
skip_odforce Posted March 9, 2015 Author Share Posted March 9, 2015 You can delete by the primitive number. So in a Blast SOP or Delete SOP, write '4' in the Group-field and you will delete that Surface volume example. Skybar , thank you so much. Quote Link to comment Share on other sites More sharing options...
edward Posted March 10, 2015 Share Posted March 10, 2015 You can also use @name=<name> in the group field. For example: @name=surface Quote Link to comment Share on other sites More sharing options...
