JonathanGranskg Posted March 10, 2015 Share Posted March 10, 2015 I'm using wires deform a ton of points and it is terribly slow and the capturing process is what's taking the longest by far. Preferably, I'd like to recreate it in VOPs or VEX. So does anyone know how the Wire Capture node works? It sets four attributes, but I don't know what they mean. I guess the ones ending with w are some kind of weighting. wireCapture regn[0] wireCapture w[0,0] wireCapture w[0,1] wireCapture w[0,2] In my case the regn and w[0,2] are both set to 0.0 and the w[0,0] is set to 1.0. The only one varying is w[0,1]. So what does the value mean? I think it's some kind of position along the length of the curve... Quote Link to comment Share on other sites More sharing options...
pbarua Posted March 10, 2015 Share Posted March 10, 2015 Check these: http://www.fourthwall.ndo.co.uk/HT_Otls.html http://forums.odforce.net/topic/8877-gmvc-general-mean-value-coordinates/ Quote Link to comment Share on other sites More sharing options...
rafaelfs Posted March 10, 2015 Share Posted March 10, 2015 I'm using wires deform a ton of points and it is terribly slow and the capturing process is what's taking the longest by far. Preferably, I'd like to recreate it in VOPs or VEX. So does anyone know how the Wire Capture node works? I thought I had issues with capturing in the past and it turns out that I was cooking my capture at every frame, which was an issue with how I wired my network. You might want to check tor that or if it still doesn't work, look at the pointdeform SOP: it's an asset built mostly with wrangle nodes and the code is all exposed for your learning pleasure! Cheers Quote Link to comment Share on other sites More sharing options...
JonathanGranskg Posted March 10, 2015 Author Share Posted March 10, 2015 I thought I had issues with capturing in the past and it turns out that I was cooking my capture at every frame, which was an issue with how I wired my network. You might want to check tor that or if it still doesn't work, look at the pointdeform SOP: it's an asset built mostly with wrangle nodes and the code is all exposed for your learning pleasure! Cheers I have to capture every frame because the input geo is changing every frame, but I'll take a look at the Point Deform SOP. Thanks for the replies. Quote Link to comment Share on other sites More sharing options...
michael Posted March 10, 2015 Share Posted March 10, 2015 I'd be interested in what kind of geometry you have that is changing every frame... you might want to look into using attributeCopy - capture once and then copy the capture attribs for the next frames... Quote Link to comment Share on other sites More sharing options...
edward Posted March 11, 2015 Share Posted March 11, 2015 In my case the regn and w[0,2] are both set to 0.0 and the w[0,0] is set to 1.0. The only one varying is w[0,1]. So what does the value mean? I think it's some kind of position along the length of the curve... One value should be the actual "weight" captured by the region. The other two will be the closest uv coordinate on the wire to the captured point. For curves, only one of u or v will have meaning. The both of them only have meaning if you're feeding in NURBS surfaces instead of curves. Quote Link to comment Share on other sites More sharing options...
JonathanGranskg Posted March 11, 2015 Author Share Posted March 11, 2015 (edited) One value should be the actual "weight" captured by the region. The other two will be the closest uv coordinate on the wire to the captured point. For curves, only one of u or v will have meaning. The both of them only have meaning if you're feeding in NURBS surfaces instead of curves. Alright, thanks for the clarification. Then w[0,0] has to be the weight because the weight range is set from 1 to 1. Does anyone know how I can create this type of four floats attribute by myself (it seems to have some kind of custom name per component)? I think I have an idea of how I can solve this. Edited March 11, 2015 by JonathanGranskg Quote Link to comment Share on other sites More sharing options...
edward Posted March 11, 2015 Share Posted March 11, 2015 There're known as "index pair" attributes. Last I looked, I think they can only be created in the HDK, but can be queried from HOM. 1 Quote Link to comment Share on other sites More sharing options...
