Primitive sorting
sibarrick
Turns out you can reorder prims at will using the delete sop.
Just type the order you want into the group field at the top and set the operation to delete non-selected. Just make sure you list all the prims in your object. :o
So, for a 80 poly sphere if you want to swap polys 71 and 72 just put
0-70 72 71 73-79, and behold 71 and 72 get swap around.
So there you go Anakin78z you can do it after all, no need for otls or expressions in the sort sop. :ph34r:
Wow. That's pretty handy.
Can't wait to confuse myself with that one, someday very soon. B)
Great find!
Cheers,
G
13925[/snapback]
