Selecting start points in chop and create a line
this is the input from a midi-in chop.
I would like to get only the starting points, where the midi-file changes notes.
And then create a line between these points, I guess that can be done with the add sop.
But how to select only the start points. A trigger chop would give me the right time, but not the value at that position.
Checkout the function chops(opinputpath(".",0")). This should get you your starting value from there chop channel.
For instance, use a Shift node (in CHOPS context) and then place the expression -chops(opinputpath(".",0")) in the Start field. This will create a shifted chop whose start will always be at 0. Then you can use a Delete by pattern 0 (non-selected) to fetch that value.
chops gets you chop start.
chope gets you chop end.
Edited by Atom
Thank you sadhu!
That definitely catches some of the points:
I can't say that I understand what it does though.
Now I'm readign that the chopi expression function evaluates a channel at a given sample point.
Ok, so the expression compares the points and if the y-value is higher than the one before it is kept, otherwise it is set to 0.
Changing the > to a < produces the remaining points.
How does one rewrite the expression so that it matches points bigger than or smaller than the
point before?
Then I can probably just use a delete and delete all points of value 0.
