ayidi Posted March 20, 2015 Share Posted March 20, 2015 I've found GEO_AdjPolyIterator but it only has breadth-first search. Are there more graph traversal algorithms in the HDK? Quote Link to comment Share on other sites More sharing options...
petz Posted March 22, 2015 Share Posted March 22, 2015 I've found GEO_AdjPolyIterator but it only has breadth-first search. Are there more graph traversal algorithms in the HDK? not that i know of, but depending on your needs you might want to take a look at bgl (boost graph library) which is included in the hdk Quote Link to comment Share on other sites More sharing options...
ayidi Posted March 23, 2015 Author Share Posted March 23, 2015 ok thank you Quote Link to comment Share on other sites More sharing options...
edward Posted March 23, 2015 Share Posted March 23, 2015 What are you trying to do? Should be easy enough to have a UT_BitArray for all the visited points and then just walk the geometry edges in a depth first manner. Quote Link to comment Share on other sites More sharing options...
ayidi Posted March 23, 2015 Author Share Posted March 23, 2015 What are you trying to do? Should be easy enough to have a UT_BitArray for all the visited points and then just walk the geometry edges in a depth first manner. I need to traverse a non-const gdp that contains a mesh and a starting point using DFS. Yes I'm currently using UT_BitArray and GEO_HedgeInterface. For reference what are other ways to walk the geometry? (non-const/const) Ex. - GEO_HedgeInterface (non-const) and GEO_DetachedHedgeInterface (const) - GEO_AdjPolyIterator (non-const) - GA_Edge (requires manual population) - gdp->getPointAdjacentPolygons() (const) - gdp->getPrimitivesReferencingPoint() (const) - gdp->getEdgeAdjacentPolygons() (const) Quote Link to comment Share on other sites More sharing options...
edward Posted March 24, 2015 Share Posted March 24, 2015 Don't forget that you can also go from point to vertex, vertex to next vertex, and then from vertex to primitive. Once you have a primitive, you can just in turn traverse the vertices to get a the points. 1 Quote Link to comment Share on other sites More sharing options...
ayidi Posted March 24, 2015 Author Share Posted March 24, 2015 Don't forget that you can also go from point to vertex, vertex to next vertex, and then from vertex to primitive. Once you have a primitive, you can just in turn traverse the vertices to get a the points. Perfect thank you. I couldn't find them at first because I was expecting the name of the method to have a "get". Here are the methods: gdp->vertexPoint() gdp->vertexPrimitive() gdp->pointVertex() gdp->vertexToPrevVertex() gdp->vertexToNextVertex() gdp->getVertexReferencingPoint() gdp->getVerticesReferencingPoint() Quote Link to comment Share on other sites More sharing options...
