Juzwa Posted April 24, 2015 Share Posted April 24, 2015 (edited) Hi, Can anyone pls enlight me how to make houdini autosave on default? I don't want to set this everytime I launch H Edited April 24, 2015 by Juzwa Quote Link to comment Share on other sites More sharing options...
pezetko Posted April 24, 2015 Share Posted April 24, 2015 Hi, In your $HOME/houdniversion/scripts folder create 456.py file with this content: import hou hou.appendSessionModuleSource('''hou.hscript("autosave on")''') 4 Quote Link to comment Share on other sites More sharing options...
pbarua Posted April 25, 2015 Share Posted April 25, 2015 Edit > Preferences > Save Options. Quote Link to comment Share on other sites More sharing options...
vitayeung Posted March 1, 2016 Share Posted March 1, 2016 Hi, In your $HOME/houdniversion/scripts folder create 456.py file with this content: import hou hou.appendSessionModuleSource('''hou.hscript("autosave on")''') May I ask a silly question? Why does it have to be 456.py? I changed the file name and the code stopped working. Quote Link to comment Share on other sites More sharing options...
pezetko Posted March 1, 2016 Share Posted March 1, 2016 http://www.sidefx.com/docs/houdini15.0/hom/locations#initialization-scripts Quote Link to comment Share on other sites More sharing options...
vitayeung Posted March 2, 2016 Share Posted March 2, 2016 oh cheers I got it! Quote Link to comment Share on other sites More sharing options...
Krion Posted March 26, 2016 Share Posted March 26, 2016 Hello i have a question about this; i can't find the scripts folder you are talking about Also; there is no folder called 'Houdini 15' or something in my home folder. (mac) the only scripts folder i can find is in my project folder, but that is project based, right? And how do i create a .py file? Quote Link to comment Share on other sites More sharing options...
michael Posted March 26, 2016 Share Posted March 26, 2016 on mac it will be in /Users/yourName/Library/Preferences/Houdini I always drag this Houdini folder into my sidebar for quick access. in there you will find a folder for every version major/minor version of Houdini that you have installed (14.0, 15.0 etc) this is where Houdini stores all sorts of preference files and installed plugins... a .py file is a python file just open a text editor (not TextEdit.app - it sucks) and write the code you want/need (it must be valid python code) and save it with the .py extension Quote Link to comment Share on other sites More sharing options...
Krion Posted March 27, 2016 Share Posted March 27, 2016 (edited) Thank you so much Edited March 27, 2016 by DévinOdforce Quote Link to comment Share on other sites More sharing options...
michaelb-01 Posted March 20, 2018 Share Posted March 20, 2018 I'm trying to set this up for the whole studio, I have it working in my 456.py with: hou.hscript('autosave on') But autosave defaults to save every 1 minute, how can I change this (through the 456.py or some other method) to every 10 minutes for example? I can't find anything relevant in hscript or hou.. Quote Link to comment Share on other sites More sharing options...
Krion Posted April 23, 2020 Share Posted April 23, 2020 (edited) Someone else noticed this doesn’t work anymore in H18? At least with me it doesn’t.. I am on Houdini 18.0.416 right now. Did anything change? Thanks again, Edit: Not needed anymore. It just works now. Edited May 4, 2020 by Krion Quote Link to comment Share on other sites More sharing options...
larry briet Posted May 8, 2020 Share Posted May 8, 2020 On 4/23/2020 at 6:07 PM, Krion said: Edit: Not needed anymore. It just works now. I does not work for me... on H18 on linux. Can't make autosave on by default. Am I missing something? Quote Link to comment Share on other sites More sharing options...
pezetko Posted May 26, 2020 Share Posted May 26, 2020 You can try to set it in your 456.cmd file in $HOME/houdiniX.Y/scripts/456.cmd (X=Major version, Y=Minor version, e.g.: 18.0) directly: autosave on https://www.sidefx.com/forum/topic/25350/ Or you can ask the user what they want: https://www.sidefx.com/forum/topic/12971/#post-61684 I like the idea of having it in File Menu under File Save As too: https://www.sidefx.com/forum/topic/12971/#post-256607 Environment variable to force it on/off wouldn't be bad but it is a little bit harder to discover: https://www.sidefx.com/forum/topic/45068/#post-201467 and there is already plenty of other options. Always on in preferences (GUI) was probably already requested, but you can add RFE (voice) for it too. Quote Link to comment Share on other sites More sharing options...
Krion Posted March 12, 2021 Share Posted March 12, 2021 (edited) On 4/24/2015 at 5:54 PM, pezetko said: import hou hou.appendSessionModuleSource('''hou.hscript("autosave on")''') Just curious, regarding the Python method, what's the Python 3 version of this? Didn't have the time to look into the differences between Python 2 & 3, but I am going to look now in that 456.cmd method and watch those links. Asking the user seems like a nice option indeed. EDIT: both 456.cmd versions do not seem to work. I am on version "18.5.462 Python 3". Edited March 12, 2021 by Krion Quote Link to comment Share on other sites More sharing options...
pezetko Posted March 12, 2021 Share Posted March 12, 2021 Hi, it should be the same. Just tested both 456.cmd and 456.py on 18.5.514 (apprentice) on Windows 10 and it is working fine (456.cmd script is running on scene open/new file). O would prefer 456.cmd over 456.py as the python version modifies the session module and it could result in inserting this script multiple times if you don't add guard against that. Btw: Now the 123.py works only in Houdini FX. The Core has houdinicore.py instead. https://www.sidefx.com/docs/houdini/hom/locations.html#startup Alternatively, you can use pythonrc.py it is running only on startup (same as 123 scripts). But for always-on autosave, I would go with 456.cmd variant. Quote Link to comment Share on other sites More sharing options...
Krion Posted April 5, 2021 Share Posted April 5, 2021 (edited) Thanks, it was actually something else in my packages folder that was causing the issue. The Houdini ToolBox library. After deleting that now the autosave scripts work. (btw I pressed sideFX in an RFE too during this time that they should make this an ui option) Edited April 11, 2021 by Krion Quote Link to comment Share on other sites More sharing options...
