magneto Posted May 5, 2015 Share Posted May 5, 2015 Hi, In standard volumes, you are able to do this using the Volume SOP. But for VDBs, is there a way to create an empty volume using a fixed size or bbox? I just want to populate the values later myself using the Volume Stamp SOP. If the VDB already has 1 as density, then the stamping doesn't work correctly. Thanks Quote Link to comment Share on other sites More sharing options...
DLCool Posted May 5, 2015 Share Posted May 5, 2015 Try this: emptyVDB.hipnc Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 5, 2015 Share Posted May 5, 2015 Just lay down a VDB SOP. The thing that makes VDBs awesome is that it only uses active voxels, so I think it's kinda destroying the purpose filling an entire box with empty voxels when you could just not create them at all until they are needed. I guess it kinda depends on the case, but when it comes to VDBs you need to think a bit different than with regular volumes. Example with the Volume Stamp SOP: volumeStamp_dv.hipnc 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted May 5, 2015 Author Share Posted May 5, 2015 Thanks guys that fixed my problem Quote Link to comment Share on other sites More sharing options...
