Trouble controlling orientation of an object copy along a curve
Hi there,
I'm was just messing around building a fence in Houdini and I came across this issue...
Screen%20Shot%202015-05-09%20at%201.15.4
I really want the fence posts to face along the direction but to stand up completely straight.
Does anyone know how I can get this to work?
Here's my scene if anyone has a sec to check it out.
http://www.naffupdate.com/forumfiles/FenceIssue-veZ1RibM0H.hiplc
Screen%20Shot%202015-05-09%20at%201.22.5
Thanks!,
Pete
if you still need to keep planks aligned to the curve, you need the tangent, so polyframe is handy, however, you can use it to compute up vector and use {0,1,0} as N to keep them exactly upright
you can as well use template group to isolate main and inbetween points before copy to streamline the flow a bit, instead of branching to soon, therefore avoiding duplicate nodes (like ray and polyframe nodes), but as well solving problem of overlapping planks from both copies
FenceIssue_fix.hiplc
Edited by anim
  • 10 months later...
Hey sorry to bring this thread back up but I've been refering back to it every now and then and I just noticed something that was causing me a little trouble.
If I try to make the normals look at a point (as in your tute) it seems that they look at a point that is in a slightly different position.
Do you know what might cause that?
Screen%20Shot%202016-03-29%20at%201.45.5
Thanks,
Pete
