tutorial problem
Hi guys,
New to the forum and houdini, started with some tutorials and I got stuck.
8.25 the Absolute is plug in, from what he explains, the node can convert "negative values into their positive equivalent."
When I do so, I don't get the same effect. My Point Trials are still pointing downwards (negative) , not upwards (positive)
Sorry this is such a basic question!
post-13612-0-26191700-1431470233_thumb.p
test_02.hip
yep - you can add a 'v' Visualizer that will recreate the older style in H14.
Press 'd' key over the viewport, under the Visualizer tab, add a  Scene Visulaizer,  set the Attribute to v, Style to Vector and Type to Marker. You may want to adjust the Length Scale too.
