Point Normal - Control each point's normal separately
chishbak
Hi guys
Does anybody knows  a method to rotate separately  each normal of a point from a curve ? I  want to select 1 or X number of  points  and than to rotate their  normal as desired.
how to do that?
Thx
Edited by chishbak
Another option is to move each point in the direction that you want its normal to point.  Then using a point sop, connect your original points into the first input and the edited points into the second.  Then for the normal use: $TX2-$TX, $TY2-$TY, $TZ2-$TZ.   This will set each normal to point to the position of the edited points.
Houdini world is divided into those who use quaternions and those who are going to use them :)
Now say you want to rotate Normals for point num 0  1 and 2 by 45 degrees around X axis.
Laydown attrib wrangle enter @ptnum == 0 1 2  in Group field and following in VEXpression field :
float angle = radians(45);
vector axis = set(1,0,0);
vector4 myQuaternion = quaternion(angle,axis);
@N = qrotate(myQuaternion,@N);
