where is the main vop output???
hi everybody
in vop context, if the four opinput string in geometry vop global param are the vop-node's inputs, where can i find and feed the output of the node?
basically, I want to create a switch node in vop and create conditions inside who toogle inputs to feed the output...
i joined a basic setup of what i want
best regards
Hugo
vop_main_output.hip
thanks for your reply,
i know how to bind export attribute or param but it s not what i need...
i really want to create a vop switch who pipe one of the four inputs in the output depending on conditions inside the vop network
best regards
VOPs don't have multiple outputs in the way you're talking about. The only thing difference though between your two inputs is the airresist so what Sadhu is suggesting sounds the right way to go to me.
hello guys,
not looking for multiple outputs!!! just one, the main one! but  if it isn't possible maybe something else...
Sadhu,Jooey, i undertand what you mean, but it's not what im looking for!
i try to change the input index of a switch depending on an attribute, the drag node and air resist attribute  are here just to test...
---> age drive the switch inputs who decide if the drag is active or not!
is it clearer? if there is a way to put some vex in a standard switch node could you tell me how???
thanks by advance
unfortunatly it dosen't work for what i need...
i just want to filter a sop solver by attribute or group
the switch was the first option i ve found but it dosen't work
the group field of the sop solver dosen't seem to show me my groups..
could you help me to achieve that???\
basically i want to filter my points by the myage attribute i created, to decide if the solver update them or not...
i join you the file im working on
PS: i open a new topic specific to this question...
DISAPEAR.hip
