copy object to particles problem ...
I am still learning about copying geometry to particle simulations.
I am having trouble understanding why my static collision objects are being included in my copy. I know I can delete them afterwards ... but is there a better way ?
I have included a .jpg that show the problem and my simple test .hip file.
Thanks !
post-9575-0-70238000-1432571072_thumb.jp
simple_copy_particles.hip
T H A N K    Y O U
learning this stuff has been a bit problematic since most of the learning material is from v13 and before.
Is it better form to keep the popnet out of the geometry node then ? placing it in a dopnet at the object level ?
Thanks again !!!
Edited by Mdonovan
Thsnk Georgie this helps a lot.
I learned three ways to do random particles scaling.
  1. Attribute Wrangle
  2. Point Vop
  3. Point Sop
They all use ID.
I am still confused about when I can use $ID though.  Like when do you use $ID vs. @id vs i@id
Ill get there.
