Separate import dop from different smoke source
kaworuonline
Hi all,
I have two different density source in my smoke sim,
why can I import them separately through dop I/O?
I found there is index field called "sourceindex", can i separate the smoke using this data?
Any idea how to proceed?
Hope it is not stupid question :blink:
You can't really. Your two density sources are emitting into a single density field - there is no way of telling which source this density came from when it is all mixed up. I guess it COULD be possible using some additional fields but thats nothing I've ever tried. If you really need to be able to seperate the two I guess just creating a simulation for each source is the simplest. Or well you could do some clustering-thing where you have one container for each source.
