mask surface tension
csp
Hi,
I have two sources in a flip solver and I want to have different surface tension to each one of those sources, how that's possible? In general how the group parameter in a gas microsolvers as surface tension can be used in order to effect part of a flip silumation?
Or is there any way to mask it? I tried unsuccessfully to create a new scalar field matched to surface and use it as mask using gasparticletofield which was reading particle custom attribute where points of one source had value of 1 and the other of 0. Then I replaced Surface Field parameter in Gas Surface Tension with that mask filed, but as I said it didn't worked.
regards,
Christos
Thanks David, this what exactly I was trying to do with the masking method but instead of gasparticletosdf I used gasparticletofield as I described above. Thanks again.
It would be nice if surface tension was like viscosity or density which can be attribute driven.
