magneto Posted June 13, 2015 Share Posted June 13, 2015 Hi, I have geometry data called Geometry in a dynamics object and a field called density. I want to create points every frame using this density field and save them onto Geometry. I am using a SOP Solver. If I use density, then I can get the field from this dynamics object but when I create points the simulation stops getting density as it becomes points. So I can't do that. If I use Geometry in the SOP Solver, then I get Geometry but I don't know how to get density because it's not like in SOPs. How can I achieve this? Thanks Quote Link to comment Share on other sites More sharing options...
Skybar Posted June 13, 2015 Share Posted June 13, 2015 Not sure what you mean. Example hip? Quote Link to comment Share on other sites More sharing options...
magneto Posted June 13, 2015 Author Share Posted June 13, 2015 I made a simple file. I am trying to accumulate new points generated using scatter on the density field, but I don't know the best way to do this because if I type density on SOP Solver, then I get the volume, but I can't modify "particles" data. If I bring "particles" data then I don't know how to bring in density field. Am I missing a simple step? sopsolver.hip Quote Link to comment Share on other sites More sharing options...
Skybar Posted June 13, 2015 Share Posted June 13, 2015 (edited) Like this you mean? sopsolver_dv.hipnc edit: The "Data Name" on the SOP Solver acts like a promoted parameter really. You can see on the "dop_geometry" inside that the "Geometry Data Path" grabs this. This node is a Dop Import SOP as well, so you can import anything from dops if you want. Edited June 13, 2015 by Skybar 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted June 13, 2015 Author Share Posted June 13, 2015 Thanks a lot David, exactly what I wanted Quote Link to comment Share on other sites More sharing options...
