Animate values inside nodes
Hi All
Sorry if this has been asked before but i'm not able to animate values inside nodes.
I'm trying to animate speed value inside ocean spectrum node but it dosent seem to register that..
I've just started with hodini so pls bear with me.
Thanks
Sandy
the easiest way is to RMB on the parameter and select "Channels and Keyframes"> Set Keyframe (Alt+LMB)
then move the timeline to the new frame and repeat the above
then RMB on the parameter and select "Channels and Keyframes"> Scope Parameters
this will pop up the animation editor...there you will see what is happening with your keys
HTH
oh sure there are hot keys for everything...but I find when just starting out it's better to do things 'by hand' - you see where stuff is and learn a workflow...then later you know what you want and you just want it fast :)
