How to retime Alembic camera
Hi Guys I have a Maya scene exported out as Alembic cache. It has a very fast moving characters and camera. I want to retime the cache and slow it down. It was easy to retime the characters with Timewarp but how do I retime the camera Please Help.
Also what would be the best solution to sim fast moving objects Substeps or retiming the shot.
Thanks
  • 4 years later...
  • 1 year later...
scorpes
here is the thread showing simplified chops stretch method to retime the camera animation I thik this is for houdini camera
https://forums.odforce.net/topic/27299-camera-motion-retime/
for alembic camera there are 2 Frame related parameters Frame(adjust the start frame to match the fps)  and Frames per second(multiply with the amount of slow motion needed like( 1/2 speed means 2 and quater means 4)) of the Alembic  Archive obj  file adjusting them will make the camera/animation/whatever inside gets slow motion. probably duplicate the alembic cam and rename as slow motion
Edited by nAgApAvAn
found accurate solution
