flip whitewater source
I'm setting up a new flip sim - open ocean shot.
main flip sim so far looks good.
But whitewater source is causing problems. When using "volumes and particles" as source I get nothing with vorticity, When using "Particles only" I get this: (see image)
Also trying acceleration or curvature gives not one good source for foam emission - didnt have that before
any idea whats causing this?
post-4280-0-24948300-1437512748_thumb.jp
Edited by borisb2
no, its the wavelayer setup with some customized velocities (around the boat). Seems like this is happening only on this cache - a different cache-version doesnt show that behavior.
As mentioned, also acceleration and curvature are showing weird results (stretched)
  • 2 years later...
On 09.02.2018 at 2:16 PM, djwarder said:
Anyone else having the same issue as this?
Getting similar results from sims using Guided Ocean Layer and not getting very nice source for whitewater.  Any fixes to get round this at all?
What do you mean "not getting nice source for whitewater"? Can you show the picture?
Seem to be getting lots of pockets of velocity under the surface and also around edges.  Makes sourcing nice whitewater emission pretty tricky!
This screenshot shows a bit of the issues - side view of a ww source from a flipsim (guided ocean layer) with a collider on surface and then saved out via fluidcompress ...
Edited by djwarder
Massive image!
you can easily creat your own emission criteria. No need to use shitty houdini-one.
Just sample in a VOP neighbor velocities, subtract from current points velocity and fit range length of that vector into emission criteria. Remove all points that dont meet emission criteria . thats just one way
