Mdonovan Posted July 31, 2015 Share Posted July 31, 2015 (edited) Hey Guys, I am using the xColorize sop to color points on a particle emitter. The problem I am having is that even though the color points in my ramp are set to constant, Houdini seems to be interpolating through those colors. I have limited my colors to blues/bluegreens but because the value of RED is changing based on the brightness of the blue, I am seeing some purples in the end result. Any thoughts ? Thanks Mike Edited July 31, 2015 by Mdonovan Quote Link to comment Share on other sites More sharing options...
Skybar Posted July 31, 2015 Share Posted July 31, 2015 I have no idea what that Colorize asset does, so it's hard to say. Quote Link to comment Share on other sites More sharing options...
Mdonovan Posted July 31, 2015 Author Share Posted July 31, 2015 (edited) It looks like it just generates a random seed and then pulls a value from the ramp. Its part of the xTools library. I'm just going to make my own from scratch. Edited July 31, 2015 by Mdonovan Quote Link to comment Share on other sites More sharing options...
Skybar Posted July 31, 2015 Share Posted July 31, 2015 Alright, so it creates a random vector attribute which drives the ramp. Try driving the ramp with a single float attribute instead. Quote Link to comment Share on other sites More sharing options...
acey195 Posted July 31, 2015 Share Posted July 31, 2015 also because it blends between points, you may need to use a high-density "resample" node before your colorize to make the transitions more crisp. if you want there to be 0 blending at all, you will have to use primitive color instead of point color Quote Link to comment Share on other sites More sharing options...
