How To Get FORVALUE in VEX?
Atom
Hi All,
I have a Point Wrangle inside a FOREACH. I want to fetch the index of the FOR to include in my calculation.
What is the syntax?
I have tried...
i = stamp("..","FORVALUE",0);
i = ch("../forstamp");
i = ch("../FORVALUE");
The stamp issues an error in the Wrangle, the other two don't seem to work and always return 0.
stamp() is a hscript expression.
On the wrangle node you can edit parameter interface and add a int channel.This is where you will put the hscript expression.
stamp("..", "FORVALUE",0)
Then in the vex code you can reference the value by calling the channel.
int i = chi("myintch");
Edited by Alex Lombardi
Thanks for the different tips. One thing I noticed when I pasted a Relative Copied Reference into the Wrangle code box was that Houdini simply wrapped hScript with those back ticks.
I tried this code and it worked!
i = `stamp("..","FORVALUE",0)`;
So I guess you can mix hScript and VEX. I'm not sure if there is a performance hit on doing that but it is nice to know.
Edited by Atom
be careful about mixing them
by using expression in VEX, you are literally just inserting result of the expression into the code which gets then compiled as VEX
the disadvantages is that VEX compiles only on first frame, so if your expression is time dependent, it may not reevaluate
I would't trust it that much to use stamp expression in that way, go with the spare  parm
