separate closed and unclosed meshes
br1
if you lay down a divide sop check -> remove shared edges. Open geo will will leave some geometry around the open edges, whereas closed geo will leave nothing. use a switch with `npoints(path)`==0 in the input.
  • 2 weeks later...
