Atom Posted August 15, 2015 Share Posted August 15, 2015 (edited) Hi All, I have put together a simple .MTL file reader that will create a mantra surface for each entry listed in a .MTL file. Currently only diffuse and specular are only supported but it is a way to at least get all your materials created and named correctly with basic coloring intact. If your OBJ file was exported with material groups then the group names in the OBJ will match the newly create material names. Replace the file_name string variable with a path to your .MTL file. # Simple .MTL reader. # Run after .OBJ import. # Reads Blender generated .MTL files and creates a Houdini Mantra surface as best possible. # EXAMPLE: Expected format. #newmtl Reflector.001 <- Material name. #Ns 96.078431 <- Specular intensity #Ka 0.000000 0.000000 0.000000 <- Ambient color. #Kd 0.640000 0.640000 0.640000 <- Diffuse color. #Ks 0.500000 0.500000 0.500000 <- Specular color. #Ni 1.000000 <- Index of refraction. #d 1.000000 <- Opacity. #illum 2 <- Illumination model, expect 2..probably will not support. import hou cur_mat = None file_name = '/Users/Developer/Downloads/cc0_Enterprise_NCC-1701/27_Enterprise-1701.004.mtl' with open(file_name, 'r') as f: lines = f.read().splitlines() # Remove slash n character at the end of each line. f.close() for line in lines: ary = line.split(' ') if ary[0] == 'newmtl': # Grab the name of this new material and create a mantra surface that we can populate. mat_name = ary[1] # Kind of assuming that only one space will be between the token and the value. gal_entry = hou.galleries.galleryEntries('mantrasurface')[0] gal_entry.createChildNode(hou.node("/shop")) # NOTE: The newly created material is always called 'mantrasurface' so we can fetch it reliably from a constant name. cur_mat = hou.node("/shop/mantrasurface") # Set the name to the name from the .MTL file. cur_mat.setName(mat_name) if ary[0] == 'Kd': # Found a diffuse color. if len(ary) == 4: cur_mat.setParms({'baseColorr': float(ary[1]),'baseColorg': float(ary[2]),'baseColorb': float(ary[3])}) if ary[0] == 'Ks': # Found a specular color. if len(ary) == 4: cur_mat.setParms({'specColor1r': float(ary[1]),'specColor1g': float(ary[2]),'specColor1b': float(ary[3])}) cur_mat.setParms({'specColor2r': float(ary[1]),'specColor2g': float(ary[2]),'specColor2b': float(ary[3])}) if ary[0] == 'd': # Found 'disolve' parameter which is really opacity. cur_mat.setParms({'opac_int': float(ary[1])}) Edited August 15, 2015 by Atom 2 Quote Link to comment Share on other sites More sharing options...
michael Posted August 15, 2015 Share Posted August 15, 2015 NICE! Quote Link to comment Share on other sites More sharing options...
