Object sprinting across Fluids
fatboYYY
Just install a force (wind) right before gravity in your AutoDop network, the object is irrelevant in this case. You could also just animate a rigid body traveling across the surface. Then hide that part during rendering.
Edited by Atom
Adding windforce didn't give me satisfying results at all. It applied the force to all particles, while I just wanted it to affect the ones on the surface.
Animating a rigid body object only gave me results when it was directly interacting with the fluid. It gave me mediocre results, but it's a starting point.
