Write To A Parameter Using VEX?
Atom
HI All,
I know how to read a parameter using vex via the ch("my_parameter) function.
How do I write a result back to that parameter inside a vex snippet?
For instance this does seem to be valid vex code, it does not throw an error but it also does not work.
ch("my_parameter") = 1;
Edited by Atom
What is actually odd is that I just watched Peter Quint do this in his latest crowd tutorial video. He was updating the existing force value with a *= not a direct assign. However, when I tried to do this with a parameter that I had added to the interface, as you mention, it does not work.
post-12295-0-89363900-1442329071_thumb.p
Guest mantragora
If you look inside of popSteerWanderDOP => noise_force => local_noise, you will see that there is a snippetVOP with expression referencing VexPression field. The force value is modified after it's set in UI.
