mestela Posted September 24, 2015 Share Posted September 24, 2015 Tempted to try and implement this in mantra: http://www.psyop.tv/psyops-cryptomatte-technology-explained-siggraph-2015-poster/ Meant to do some reading tonight, but got distracted with that connecting curve post. Anyone else checked this out? I assume its possible to implement now that we can create custom filters, but that's based on hearsay and vague hand waving. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 24, 2015 Share Posted September 24, 2015 (edited) Wouldn't bother even thinking about it. Knowing how bad fully released papers translate into production code - this is simply too advertorial to even care about IMO edit: for example this type of line adds nothing -> 'Since deploying the toolset, we have received positive feedback from 3D artists and 2D artists alike. ' Show us the issues then we might care Edited September 24, 2015 by tar Quote Link to comment Share on other sites More sharing options...
mestela Posted September 24, 2015 Author Share Posted September 24, 2015 Ha, but how do you _really_ feel? I'm interested mainly because I've been been burned a few times with deep, this seems like a reasonable compromise. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 25, 2015 Share Posted September 25, 2015 I wanted to try to use alembics and Nuke's scanline renderer to do this type of thing - Mantra rendering for RGB & Nuke's scanline for some tech stuff. Maybe it's only good for small stuff though. What are your thoughts on custom filters? Not sure how that fits into this. Thanks! Quote Link to comment Share on other sites More sharing options...
mestela Posted September 25, 2015 Author Share Posted September 25, 2015 From my super limited understanding, you'd need to access the samples before filtering to create your own coverage mattes and whatnot. I haven't delved into that side of mantra at all though, so i'm likely completely off base. Gonna try and have a closer look over the weekend. Then there's the issue of creating matching nuke nodes to make sense of these mattes... hmmm... Quote Link to comment Share on other sites More sharing options...
fathom Posted September 25, 2015 Share Posted September 25, 2015 or you don't filter. i've done a version of this in the past -- render your beauty like normal, then run a matte pass with the "sub-pixel output" toggle engaged. for our purposes, we just had a shader that stuffed in the current prim, a material id (integer), and an object id (also an integer). those became red, green, and blue in the rgb. in nuke, you just pick a color for which item you want and then generate a matte channel based on your selection. then you reformat down to your rez and you're good. works great except for transparency/volumes (and ray tracing, but that's asking too much). motion blur works fine with this if you have enough samples. the image size isn't too crazy either since you've got relativelylarge blocks of solid values (no anti-aliasing). 1 Quote Link to comment Share on other sites More sharing options...
mestela Posted September 26, 2015 Author Share Posted September 26, 2015 Yep, we've done similar things too, but there's always a caveat of this or that, and as the amount of grade mattes requested by DI/comp become non trivial, even with automation it takes time for lighters to setup them all up. The tone of the paper (and discussion on mailing lists) implies that Pysop have worked out a lot of those edges cases that take up 90% of the time, so colour me intrigued. Dof and motionblur and transparency and mostly automatic setup for grade mattes, without deep? Witchcraft. Quote Link to comment Share on other sites More sharing options...
fathom Posted September 26, 2015 Share Posted September 26, 2015 (edited) you can let houdini assign the objectid for you, but then it's possible to change, so it's probably best to have an artist handle it (perhaps with some ability to verify that it doesn't collide with some other id). same with materials -- you can have an id built into the material itself or give the artist the ability to select it. primitives are automatic and with polysoups it's super-easy to get things id'd by contiguous sections of polys. dof and motionblur are trivial since they're handled by pixel samples. i suppose you could probably do screendoor transparency with this system, but you'd need to crank the hell out of your pixel samples i'm thinking. honestly, i don't really see anything mindblowing here. not sure why they bother with the id mapping to real names. most art direction is going to be visual so directly selecting the item would seem to make more sense than determining the name of the item you want. unless, i suppose, the numbers change from shot to shot and you want to move your nuke script to another shot and still have it work on the same objects. Edited September 26, 2015 by fathom Quote Link to comment Share on other sites More sharing options...
paxsonsa Posted July 14, 2016 Share Posted July 14, 2016 Hey all, The team at Psyop just open sourced their ID matte toolset called cryptomatte. I started working there a couple months ago. We are looking from some contributors for Mantra implementation for the project! anybody interest? https://github.com/Psyop/Cryptomatte Have look and if your interested or can help out hit up the team, we are eager to make this apart of mantra and Houdini Cheers! Quote Link to comment Share on other sites More sharing options...
martinkindl83 Posted July 21, 2016 Share Posted July 21, 2016 Quote Link to comment Share on other sites More sharing options...
