lorduk Posted November 28, 2004 Share Posted November 28, 2004 just tring thing here but when I import the PFtrack .clip file the axis are all wrong - has anybody used PFtrack, or I am better off working it out with pixel farm support? -Kaspar Quote Link to comment Share on other sites More sharing options...
stevenong Posted November 29, 2004 Share Posted November 29, 2004 Hi Kaspar, I used Icarus before Pixel Farm bought the code & everything seems to work fine. Though this is a long time ago so something might have changed. Houdini's negative Z goes away from the camera so is there somewhere to specify that? Since it is a .clip file, you can append a Rename CHOP to... erm... rename "tx" to "tz" for example. If all else fails, PF support will be your best bet. Cheers! steven Quote Link to comment Share on other sites More sharing options...
edward Posted November 30, 2004 Share Posted November 30, 2004 You might also be able to use a Transform CHOP. Quote Link to comment Share on other sites More sharing options...
