cwalrus Posted September 28, 2015 Share Posted September 28, 2015 Hello, I'm trying to get an FBX from Maya to Houdini - and using the most basic default settings, it crashes consistently. For example, create sphere in Maya, animate, export as FBX with defaults, go to Houdini, import with defaults : CRASHOLA I'm using Apprentice today, but I don't believe that is the issue. Also I'm on a 5k iMac, but once again... don't think that's the issue? I feel like it is in the settings at one end or the other. Any help would be greatly appreciated! thanks Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 28, 2015 Share Posted September 28, 2015 It's probably your iMac but to check can you upload your file and we can test on our systems. Quote Link to comment Share on other sites More sharing options...
cwalrus Posted September 28, 2015 Author Share Posted September 28, 2015 thanks, that would be great. Here's a simple FBX exported from Maya: test.fbx.zip Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 28, 2015 Share Posted September 28, 2015 Yep - that crashes on OsX H14.0.467, Nivida 980, OsX 10.10.5. It would be worth sending into SideFx as a bug report. Support menu/submit bugs on www.sidefx.com Quote Link to comment Share on other sites More sharing options...
cwalrus Posted September 28, 2015 Author Share Posted September 28, 2015 That same FBX seems to import on a PC, but with a "Invalid Range Specification" warning... whatever that is Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 28, 2015 Share Posted September 28, 2015 It's not importing into Maya 2015 on OsX. 'Unrecognised file type' Quote Link to comment Share on other sites More sharing options...
cwalrus Posted September 29, 2015 Author Share Posted September 29, 2015 Bug report submitted- The side effects peeps asked to try with latest build, which i did with same results. Quote Link to comment Share on other sites More sharing options...
Atom Posted September 29, 2015 Share Posted September 29, 2015 It does work using H14.396 (which appears to be the last stable build in the H14 series). I get the Invalid Range Specification too but no crash and the animation works. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 29, 2015 Share Posted September 29, 2015 Fwiw; Imports fine into H13.0.621. osX Quote Link to comment Share on other sites More sharing options...
